Y33/HY33 ?
blind6
Car: was a 1997 Infiniti Q45
I did a search (might have used wrong keywords) and posted under Online MechanicAre these suspensions compatible? Looking to see if shocks/springs for a HY33 will go on a Y33. Any help is appreciated.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Don't know to which suspensions you are referring, but the G50 is lableled HG50 on the firewall.
blind6
95-99 Gloria/Cedric are the ones that I found labeled HY33
Falkdesigns
Car: 1998 Q45t ~ EXE
HY33 is a Cedric. The chassis is the same, you can use the same springs and shocks as the cars weights are very similar and in Japanese magazines, or catalogs, most suspension parts show the multiple Y33 chassis listings for XYZ part number.
blind6
So if I were to put HY33 springs on my Y33 what shocks could I utilize? I think I read that lowering springs reduce shock life by 40%, is that correct? If that's the case could I run regular shocks with the understanding that they'll need to be changed sooner?
Falkdesigns
It's pure speculation as to how much it may reduce shock life. I would say for stock shocks that's probably pretty accurate, but for high performance shocks that were made for stiffer, lower springs, it's not accurate. It also depends on how you drive, I drive fast and aggressive, but also gentle, if that makes any sense.
The KYB SR Specials part number NSC6004 FRONT and NSG9069 REAR for Nissan Cima (Q45) FHY33/FGY33 is also the same part number for Nissan Cedric HBY33/HY33/PY33/UY33 and Gloria HBY33/HY33/PY33/UY33.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Falkdesigns wrote:HY33 is a Cedric. The chassis is the same, you can use the same springs and shocks as the cars weights are very similar and in Japanese magazines, or catalogs, most suspension parts show the multiple Y33 chassis listings for XYZ part number.
Cedrics and Glorias used did not use the VH41DE, but smaller but iron block VG30DE, and later VQ30DE with some turbos thrown in. I would worry about the front springs from these cars, especially if lowered.
blind6
These are a Tein aftermarket setup that I am talking about, not the factory setup. What is the worry with the front springs? You lost me.
Falkdesigns
In other words, the part numbers are the same for these aftermarket KYB shocks. They're what I have on my Q, and I have Tein's on my Q which fit's Cima, Cedric and Gloria Y33 chassis cars.
Brian, the engines weigh almost the same thing, so that's not a concern. The KYB and Tein part numbers say they work on the standard Cima (V6) AND the Cima V8.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Falkdesigns wrote:Brian, the engines weigh almost the same thing, so that's not a concern.
I imagine they are close as the VG30DETT is fairly close to the VH45DE. The VG30 iron block adds some extra.
blind6
Falkdesigns wrote:In other words, the part numbers are the same for these aftermarket KYB shocks. They're what I have on my Q, and I have Tein's on my Q which fit's Cima, Cedric and Gloria Y33 chassis cars.
Little misunderstanding, Falk I knew what you were saying, I did not know what Maxnix was getting at. Thanks for the clarification though.
blind6
What is the american version of the Cedric and Gloria?
Q45tech
No North American version.
blind6
Oh.....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:No North American version.
The US only recieved the upmarket FY33 Cima with the VH41DE, but no AWD versions.
Falkdesigns
We DID receive a North American version of the Cedric, not on the Y33 chassis, but the Y34 chassis, it's called the first gen M45 (2003-2005).
blind6
Falk, any word on your springs you ordered? Is there a set still up for grabs?
Falkdesigns
There is still a set available. They should be here pretty soon now too.
