Sorry whats a VH45DE??maxnix wrote:No, it takes a couple more turns than a VH45DE for example. Don't know why.
Interesting, but why is all this stuff only effect the way my Q starts?None of my other infiniti's or an fuel injected cars that I have owned for that matter have had this problem.Q45tech wrote:Depends on the bleed down rate of fuel rail pressure. Mostly the temperature of valve and piston crown and the volitility and Reid vapor point of the fuel you have in tank.............how many days old it is from refinery. Every day older is a bad day...........vaporwise.
Its the engine code from a 90-96 Q45 aka G50 Chassis.GM991 wrote:Sorry whats a VH45DE??
So what you are saying is it's the nature of the beast?I have owned two other Infiniti's and both started quick then this one.Made me wonder way.Also I'm guess holding down the gas a little when I go to start it will do me know good?
thanksGM991
so the y33 has no gas at start up and thats way it seems to start hard?CrimsonQ wrote:
No no gas on start!
I think he means you should enever press the gas pedal on any fuel injected car at start up, unless trying to resovle a flooded condition.GM991 wrote:so the y33 has no gas at start up and thats way it seems to start hard?
so what are you saying waiting for 3 beeps of the seat belt/door warning before trying to start the carwill give the fuel pump a second to get fuel moving?Rex wrote:Infiniti published numbers*90-96 Q45 (G50) - VH45DE - 278HP/292TQ (ex.1996, the elimination of VVT lowered the numbers.)97-01 Q45 (Y33) - VH41DE - 266HP/278TQ02-up Q45 (F50) - VK45DE - 340HP/333TQ
The layout for Nissan/Inifiniti engines is letter/letter/number/number/letter/letter/letter the first 2 letters designate the engine series (i.e. VH, VH, RB, SR, KA, FJ, LB, etc) the 2 numbers designate the displacement in liters. There may be up to 4 letters after the displacement that designate the valve train type - D = DOHC, V = VVT (though it wasn't used on the VH45DE??) (SOHC, is deisgnated by no letter), followed by the fuel system - E = Fuel injected, I = Throttle Body, D = Direct Injection. The next letters would designate what type of forced induction (& quantity ) if present - T = turbo, TT = twin turbo and R = Supercharger.
*It's rumored, that there was a gentlemens agreement amongst Japanese auto manufacturers to not export passeneger vehicles with horse power "ratings" over 300 hp. The agreement seemed to dissolve during the 90's. Keep in mind these are not RWHP numbers.
Related to the initial post, can you review your start up proceudres?
(example)Enter the carPlace key in ignition, turnWait for 3 beeps of the seat belt/door warningStart carFasten seat beltLock doorsTurn on headlightsWait ~2-3 minutes.(Note: During cooler seasons >40 degrees, after starting car, I go back in house after locking door, from passeneger side, with spare key)
Sorry for the babbling, but I thought it would be beneficial t some of the newer members .
Mine cranks strong.I really think its a fuel thingxmateo wrote:My 99 Q takes longer to crank too. I don't think it is normal though. There is a new battery, so that's ruled out. I'm thinking the starting may be on its way out.
miine has 2-3 more vr's before the vroooooom..........Falkdesigns wrote:I usually hear 3-4 cranks before it fires in the morning, like "vr, vr, vr, vroooomm".
