y33 gated shifter
rbini100
Has anyone done a gated shifter on a y33. Did any model come from the factory with one? I've seen a picture somewhere on the web and it gives a modern look to the interior of the car.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Y33 never came with one, however you might be able to retrofit something from a G50.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Seems like since it is the same transmission, maybe one off an 1996 OBD II G50 would mate up?
One of the few things I dislike about the FGY33. Nissan did everything differently from the G50, not always better.
elwesso
2007 BMW M Coupe
i really doubt they changed the shifter connections much. Point is, I doubt if it makes any difference if its OBDII or not..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Probably not, but just in case they did, i would start there and look at the connections. There are internal differences (strainer screen), so there may be external ones also.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
elwesso wrote:i really doubt they changed the shifter connections much. Point is, I doubt if it makes any difference if its OBDII or not..
actually it might as OBDII cars have a revolution sensor on top of the transmission as far as I know thats te case and that sensor is needed not to throw a code
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The OBD I RE4 have a turbine sensor also.
elwesso
2007 BMW M Coupe
yeah I dont think they really changed anything on the transmission itself, especially something that would cause a housing difference.. if anything, the changes were in how the sensor data was monitored and how codes were thrown/stored.
