Y33 front wheel bearings
Ludeaem
Car: 2000 Infiniti Q45 AE
So doing suspension and figured I'd tackle the wheel bearings in the hubs. I have TWO bearings inside the hub. Behind the seal I have a conical roller bearing and behind that I have the normal wheel bearing. Every diagram I've seen is not like this. I don't see any part number differences between touring and non touring and the FSM doesn't mention any specific procedure. I'm so lost right now.
Ludeaem
I'm wondering if I had different year hubs on the front maybe? Either way, the new wheel bearings I ordered from RockAuto appear to be wider in diameter. I think i'm going clean, repack the roller bearing, new oil seal and ship it.
fontana dan
Car: 1997 Infiniti Q45
Did you figure this out? What is the part # you ordered from Rockauto?
Ludeaem
I never did no, I ended up cleaning and repacking the conical bearing and slapping it back together. I figured front hubs are easy to take off and in the event it NEEDS to be done I'll either have an answer from here or just figure it out.
WJB WT517010
fontana dan
How is this holding up for you? I'm feeling a grinding sensation from the front left on my Q45.
Were you able to repack it? Bearing no. SKF FW216 on Rockauto wont work?
fontana dan
Ludeaem
feels fine, sounds fine luckily. I just swapped back my coilovers a few weeks ago so i had to swap the bearings and play/resistence seemed good on both. Not too loose or tight.
