paranoidjack wrote:Nice man! How much did the oem's run ya, I just put on the top of the line napa ceramix and they feel pretty good.
where did you get the parts, and do you have the part #'s? I'd love to change this stuff right now, as I have the money.
The pads were $66 at the dealer, $60 online. The rotors were $26 at Nopi online but were out of stock so I got them at Tirerack for $41-still not too bad.
The suspension parts came from infiniti-parts.comstruts-$115 a piecesway bar links-$40 or sorubber stuff-$100 or so
It wasn't hard- there's a write up somewhere- I'd second two things in that writeup and add a third1st-remove the ABS sensor at the connector inside the engine compartment2nd-remove the lower control arm with the strut to avoid breaking apart the ball joint 3rd-you really need three spring compressors as opposed to two in order to compress the spring evenly.
