Skibane wrote:jrichardson wrote:If my understanding is correct, there is no way that on a cold engine with the thermostat closed that I could pressurize the system enough to show a leak in a freeze plug in the block. Isn't that correct?
When it's closed, the thermostat doesn't provide a completely airtight seal. There is a small "jiggle valve" on the thermostat that always allows some coolant (or air) flow, even when the thermostat is completely closed.
Also, there is no thermostat on the return (bottom) side of the radiator - which means that any pressure applied at the radiator still passes through that bottom hose to the rest of the cooling system.
So, it's certainly possible to pressurize the entire cooling system when the thermostat is closed.
I agree.
to OP: any signs of overheat? possible thermostat is frozen shut (except for the trickle thru the jiggle valve)?
Try to borescope just behind the valve covers.
also, see if the leak is coming out of the bottom of the trans bellhousing (as opposed to
around the bellhousing). if so, then likely is the expansion plug (s) at the back of the block (below the heads). But I have to say-- I've not heard of expansion plugs going bad in the VH series, and even on the old cast iron detroit blocks, I never saw one blow except for extreme neglect (corrosion), or extreme overheat like a faulty thermostat or driving when the water pump wasn't.
