Y33 FAQ.. Owners please read/review
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
OK, here it is for Word users.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thanks, brian, il be sure to add it.
dirtykat
Car: 1998 q45
ever seen one on 22''s
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
dirtykat wrote:ever seen one on 22''s
Thankfully, no.
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
What about the coils???
A good # of Y33 has issues with them.
007
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Only the FGY33 had the VH41DE that has the problems with the coil packs.
The Y33 never came with the VH41DE.
miata007
1997 Q45 is not a Y33?
007
mild83
Car: 91 honda civic
Read through the Sticky. Lots of good info. I am going to likely purchase a 97 Q45t tonight w/ 111xxx miles. It is dirty and has some minor scrapes/dings on the car, interior is filthy, the driver seat and left front leather armrest are a bit rough, ie. the leather is cracked, rubbed off. The owner told me that the car has a rebuilt transmission w/ less than 3xxx miles. The left front strut is knocking/tapping, will need to be replaced. He is at $2500. There is also a bad knock sensor. Good buy or not? It seemed to run pretty good when I test drove it.
elwesso
2007 BMW M Coupe
welcome to NICO.. please start another thread and we'll go from there..
willko1
Car: 2000 q45 y33
(2000 Q45) Noticed when i pulled of the Air intake line at the Throttle Body the rubber Flanged wide o-ring that goes around the TB was cracked and falling apart this may cause some issues,
Got the TB o-ring today it is the called the "Air Tube Insulator" part #16523-31U00
ddsmith60
Car: 2000 Q45t
Thank you willko1. I found the same problem with my 2000 Q45t. Now I know what to order. If that is cracked and allowing air to enter the engine then it is unmetered (not measured by the MAF) and screws up the computer trying to control the A/F mixture.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
willko1 wrote:(2000 Q45) Noticed when i pulled of the Air intake line at the Throttle Body the rubber Flanged wide o-ring that goes around the TB was cracked and falling apart this may cause some issues, what issues Im not sure. Where can I get a replacement I wonder it looks like you may have to buy the whole elbow to get the o-oring it is not shown in diagram. All I see is the clamp for part (Item 13) 2000 Q45 Base Resonator (http://www.infinitipartsusa.com/2000-In ... /21543.htm)
Assuming you are referring to the collar (no O-ring involved) that fits over the throttle body inlet but under the intake pipe, it is not shown on that page.
16523-31U00 is for the VQ30/35DE. But if it is the same size......?
willko1
Car: 2000 q45 y33
It fit my 2000 q45 perfect and you right it was not on the parts diagram, I just asked Joe to send it and he did but I thought it would be under that diagram but your right its not?? maybe on the intake diagram that they don't have listed?
ddsmith60
Car: 2000 Q45t
How about the plastic engine fan. Mine experienced cracks all over the place in the hub area. After looking at it, I knew it needed to be replaced immediately. I believe Wilko also had to replace the fan. It goes for about $100 for the fan, new. I wasn't about to get a used one after looking at mine.
