tfvesquire »
https://forums.nicoclub.com/tfvesquire-u83121.html
Mon Jan 31, 2011 10:15 am
Yeah, on my 98, when I first started driving it I thought I was going to run out when the needle was "E" but when I filled up, it took about 15.5 gallons. I then decided to drive as far as I could until the gas light came on. At that point, I filled up with about 18.5 gallons, so on my car, you get about 2.5 gallons (21 gallon tank) reserve. I wouldn't test this theory on all 97-01 Qs since it depends on how the gas float arm is bent when it is installed. Bend it more up and you will have more reserve, bend it down and you get less. Either way, our car is too heavy to push off the road.....
Hope that helps,
Ted
