Mopar »
https://forums.nicoclub.com/mopar-u65848.html
Tue Sep 06, 2011 2:59 pm
Hello,
I cleaned my EGR port when I was doing my Knock Sensors. I believe there is no way to clean it without taking the plenum off, simply because there is not enough room in between the back of the engine and the firewall to pull out the EGR tube.
Edit: *The EGR tube is a straight metal tube that won't come out unless you remove the plenum. I highly doubt you can clean it while it is on the car...
If you have never cleaned that tube, expect it to be about 97% clogged. You can see a picture of my EGR tube in my KS thread. It was absolutely horrible!
Good luck!
