TrizzyDizzy »
https://forums.nicoclub.com/trizzydizzy-u39057.html
Fri Oct 07, 2011 6:47 pm
Hey Nico Club, been a long time since I've been here. Yall mind helping me diagnose a problem?
So starting earlier this week while sittin in my car, my Q went from a normal idle to a violent shaking rumble. Previous automotive experience helped me assume that the engine was misfiring. I took it to a local auto parts store to have it scanned. P0307 (#7 Misfire) code was up as well as P0330 (Knock Sensor). Common instinct is to replace the spark plugs and do some routine cleaning of various parts.
After the spark plugs and cleaning, the problem persisted. Did a little research to verify my assumption, then bought a single coil pack to replace for cylinder 7. After the install, problem continued to persist. Took the car back up to an auto parts store and the scanner spat out the same P0330 code, but instead of the P0307 (#7 Misfire), I get P0300 (Multiple Misfire).
So apparently the problem exists beyond just cylinder 7. Two days of research across various sites point to replacing all the coil packs and praying it works. I do not have the luxury of shelling out $600+ for a handful of hope. Do I have any other alternatives to narrowing down this problem? Have there been any new findings in this seemingly common problem? Does cleaning of the connectors/sensor often prove positive results? How would I narrow down an injector problem?
Claimed Common Fixes
- Replace ALL spark packs (Done)
- Replace ALL coil packs (1 of 8)
- Clean connectors and Sensors
- Force out carbon build up
- Injector cleaner
Disclaimers
- Prefer not to spend excess if possible
- Prefer not to take it to dealership (previous work doesn't highlight their experience well)
- I've use all OEM replacement parts
- I do have the copy of the FSM
- I do not have a have a personal scanner tool
