What does this post mean? If I'm accurate and the tone is derisive then your reading comprehension is limited. Me cutting the coil spring of another car IS real world engineering.It IS obvious that the spring rate is increased--I didn't ask that. I asked HOW MUCH of an increase?maxnix wrote:Nothing like meaningless anecdote triumphing over real world engineering.
Seems like it would be intuitively obvious that a shorter spring with consequently less suspension travel would require a higher spring rate.
Have a ball.
Your impression is correct. Brian likes to write meaningless sentences that are of no assistance and tends to turn people off. Several days ago, he stated a newbie had limited grammar, for starters, and proceeded to refer to him as an idiot. He was asked by two members to refrain or leave. Obviously he did neither.bullittandy wrote:
Mark John Crews
Is it a game, a way to be provocative for fun? Or is it just hateful? It would be nice to know because it changes the tone of his posts dramatically.mcrews wrote:
Mark John Crews
Your suggestion is on topic on two counts.qsiguy wrote:Back on subject.... ..... If you are prepared to replace your springs in the event cutting doesn't work out, why not save the trouble and just take the torch to them? I've done that on an old Chevy truck to lower it and never had any trouble with broken springs or anything and it rode quite nice for a lowerd truck.
I'll probably get lynched for bringing it up but it can be done safely if you're carefull and take it slow and if you are ready to risk messing up your springs anyway, why not? Also, if you are prepared to cut your springs, you aren't likely super concerned with the performance aspect of it, mainly the cosmetics.
Ok, I've braced myself. I'm ready for the bombardment of attacks, hehe
Who's arguing? Don't discount a valid question by a personwho may not know what oil to use. Plus, it wasn't even onyour thread! Remember people on this board are at all different skill levels. Some pro's, some DIYers.bullittandy wrote:How 'bout a real discussion about an ACTUAL modification (other than arguing over oil type)! Maybe I can lower it and retain my pillowy ride?I'll cut-then report.
A new Q driver born. Be behind the wheel before long. Congrats Falk!Falkdesigns wrote:Thanks louiegz, the reason I haven't chimed in so far, is that I was in the hospital for 4 days last week with my wife as our son was born. We came home Saturday, and I've been too in awe of our baby to do much else but stare at him and hold him!!
I have a set of stock springs coming in this tuesday and will be cuting on Friday. I'll be posting before and after pictures and will accepting apologies or well deserved "I told you so's" then.bullittandy wrote:Has anyone cut the stock front coil on a Y33? Those 2" drops with the aftermarket would be too much for me. I had my front suspension apart and it seems like it would be possible. Is the stock spring progressive on the top and bottom? I mean the bottom coil would the side to cut-how much of an spring rate increase would that be? How much to cut for a 1" drop?I know this is NOT recomended but I heard the same thing on my 55 Chevy and it rode BETTER with cut front coils.
P.S.If anyone has a set of stock front springs that they will sell me cheap I'd be much more willing to experiment.
I'm assuming that you tried cutting the stock springs on a Y33 and it didn't work. Otherwise what purpose does your opinion serve?Well I did it, I lowered my car 1" (my goal) and have not suffered any ill effects other than needing a new alignment. It seems that your post would be a "meaningless anecdote," as compared to my "real world engineering." Thanks for the compliment Maxnix-I didn't know you had it in you.maxnix wrote:Nothing like meaningless anecdote triumphing over real world engineering.
Have a ball.
Just to play it safe, I'd think you should still get the alignment. I'm not the biggest fan of lowering, especialy when you drive in bad roads like here in NJ, but those Y33 just look awful with all that wheel gap. Y33s have to be lowered. Looks good.bullittandy wrote:Turns out that after swapping tires left to right, increasing the lug torque and increasing the pressure from 32 to 35 that I don't even need an alignment!!
