dodiho wrote:elwesso...I sure enjoy all the advice you guys give us! Thanks! I have a '99 q with 124,000......I need your help! I have cleaned out my TB and MAF..both very dirty..but the problem still exists: it will start fine..idle up to 750 or so when cold....then when I put it in gear-it idles down and dies quickly.....after it warms up to center of gauge I can put in gear and EASE it up to 55 or so on the highway...but when I ask for more speed or passing gear-it sounds like it runs out of fuel as I can hear the TB sucking massive amonts of air but the speed decreases....I let off pedal and it will continue to lose speed down to about 20 mph ,then I can gently pedal it back up to 55 or so....my code reader -new one- just says air flow problem...??? I am at wit's end.....I put in new oem filter,too...stay with me on this one...thanks,guys!
dodiho wrote:El wesso...I just found out from an Infiniti tech in Dallas that one way to check the MAF/sensor housing is to tap on it near the connector and if it causes the car to stutter...then it's bad! He uses his pocket knife and taps in several places....he said it should not hesitate or stutter or die at all when one does this procedure.....so I think it was worth a cold beer and a real Texas BBQ sandwich on me to find this out...I saw him in line at a Dallas BBQ place.....!!! So i drove the 100 miles home and opened the hood of my '99Q and started the motor...tapped with my pocket knife and the damn car died instantly! The tech said road vibrations over time cause the circuit board to crack or wire solder joints to seperate! Have just ordered a Cardone rebuild and will let u all know if this stops the herky/jerky idling/driving problems!
