Y33 Cima 1997 Rear Bearing
sldwys
Car: 1991 rs13 nz new 200sx
Hey guys,
My rear bearing collapsed on me the other day and am currently without my daily ride.
I have found this part number 432100P011 to be the nissan bearing, Which im guessing i can remove circlips and press out old bearing ---> Press in new bearing.
But I am trying to find out the NSK bearing replacement part number .
Also I can match it from the measurements I have found online which is
Height 1 45mm
Height 2 41mm
ID 43mm
OD 73mm
Can anyone please confirm these measurements for me ?
qship96
Car: 1996 Infiniti Q45
are you talking about a wheel bearing? any symptoms or advance warning it was going bad?
sldwys
Yeah have pulled the wheel off and the rear and the whole bearing/hub centre moves seperatly to the brakes/hub carrier. Checked the CV Bolt and pin, all mint condition.
Car is lowrered, HAve replaced all rear arm bushes with nolathane, 240,000km on the clock.
Grinding sound from rear wheel area while driving, Gets faster and slower depending on the speed.
BEaring fell apart when I pulled hub off.
