Y33 Bose
Q_SHIP
Car: 1999 Q45T with a billion miles.
Just curious, I have had othe cars with Bose systems in the past. I have changed the decks in these cars to aftermarket setups and they worked fine with the factory bose amps still in the car with no type of converter. It was all plug and play.
Is this true with the Y33 as well?
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
I didn't want to reuse the tiny Bose amp when I did my system. The Bose amp is incompatible with aftermarket headunit, unless a converter is used.
Q_SHIP
97Q45t wrote:I didn't want to reuse the tiny Bose amp when I did my system. The Bose amp is incompatible with aftermarket headunit, unless a converter is used.
Really? What does the converter do? On all my other decks all I did was found the remote wire on the factory amps and plugged it into the one on the new deck and everything played nicely.
All the install shops said I needed a converter but I got it to work without it. Just trying to figure out if I can do this with this car.
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Some really high powered radios will overload the input stage of the Bose amps and could cause some damage over time. I run a stereo shop in Cali and we tie into the bose all the time and on your car you can go speaker level into the amps with a standard Nissan plug but if the wattage output is too high you will have very little Volume control. Meaning that two or three clicks on the radio volume will be blowing you out of the car. This is where a converter comes into play. You would then want to get a adjustable LOC (Line output converter) to adjust down the output of the deck to a more reasonable level. I have a Eclipse in my own car and just sold one to a 97 Q and they work great with no adapter required. If you feel you need one check out http://www.davidnavone.com
CheersScott
pdqwrx
Check out the NE-774V it will do the trick.http://www.davidnavone.com/adaptor_products.htm
Q_SHIP
Thats the exact info I needed. Thanks.
