DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Jun 17, 2005 7:14 pm
I think anyone who's proactive enough to add a cooler to the G50 transmission isn't likely to suffer from a line clog. The metal lines are roughly the same diameter as the rubber ones, which are used regardless.I believe, but am not certain, that an aftermarket exchanger will keep the ATF cooler than the stock exchanger. The stock exchanger has far less area, but obviously liquid/liquid exchangers do more with their surface areas than air/liquid exchangers. What I am certain of is that an aftermarket exchanger, in series with the stock exchanger, will be cooler than stock alone. Unlike plastic chain guides, cooling tubes to and from the radiator are still implemented on the newest models. The risk of clogging can't be that great.
