KingKarl wrote:I have decided to go with the MAXNIX B&M transmission fluid cooler install in the space forward of the driver's side wheel well. After looking at the pics and reading about the application, I need to ask Max (or anyone who has duplicated his procedure) to clarify:1.) - I notice your Q is on a lift...will I need to do likewise or will wheel removal and Jack stands allow me enough room to drill and mount?2.) - Is the most efficient flow to connect the the B&M cooler in series...intake line to the OEM, in-radiator cooler outflow line, B&M outflow back to transmission?3.) - How do increases in the length that the AT fluid must travel to return to the transmission effect pumping pressure/flow volume back to the transmission?4.) - Will my cousin Eric ever recover from the injuries he sustained when he tried to use aluminum lawn chairs as jack stands while changing the oil in his really heavy, Olds 442? (Max, he reallly tried this with predictable results. Luckily, the laws of physics prevailed before he was able to crawl underneath.)
1.) I am old and don't want to die under my car like Eric. On a lift, it is trivial to remove the wheel well liner and under engine tray. Job done in 30 minutes or less.
2.) Left it in series, but you certainly don't have to do this. Connection sequence is correct.
3.) Nil as pressure is constant. Slight increase in fluid volume is a slight benefit.
4.) Eric scares me.
The changes to the 1994 and later G50 ATF heat exchanger and external filtration and seemd to mitigate the woes of the earlier designs. The FY33 ATF heat exchanger design is a large step backwards, but the demands from the VH41DE and the slightly less mass of the vehicle seem to mitigate this somewhat as reported transmissions failures on this are not as common as early (pre-1994) G50. But less miles is certainly also a factor.
Excessive idling would benefit from an auxiiary fan, but most ATF heat is generated by applied power and slipping of the internal parts. Don't hold it on a hill with the throttle. I prefer this position because it is protected from stones and won't increase thermal loading on the mariginal cooling system for the engine and AC.
The great thing about the FY33 is the passenger side wheel well liner is louvered also, so an oil cooler could go over ther with only a little more difficulty.
