Y33 and QX4 radio compatability!
FarFetched
Car: Suzuki SV1000S.
I am looking to replace mine with a one out of QX4 and wandering if there is going to be a confilct with connectors or problems installing it!According to this web site http://www.carstereohelp.com/infiniti.htm theyare the same, but I don't want to end up with a wrong unit!Thanks!
Rex
Car: None
FarFetched wrote:I am looking to replace mine with a one out of QX4 and wandering if there is going to be a confilct with connectors or problems installing it!According to this web site http://www.carstereohelp.com/infiniti.htm theyare the same, but I don't want to end up with a wrong unit!Thanks!
As long as you stay away from the Maxima (2001-ish) that aren't standard double DIN, any 97 and up Double DIN Nissan/Infiniti Bose HU should plug right in to your Q.
Look for the "rare" 6-disc Double DIN unit .
Q_SHIP
Car: 1999 Q45T with a billion miles.
Rare? The past 4 Pathfinders I have sold have the 6 disc changer in them.
Rex
Car: None
Q_SHIP wrote:Rare? The past 4 Pathfinders I have sold have the 6 disc changer in them.
Was it the all in one single piece unit? or the double stack? or the in dash, but over by the glove box changer?
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
If you want to use the radio from 96 thru 98 - they should be the same CN423 / PN-2121 model. My CD player in 99'Q went south and I've replaced it (CN588 / PN-2261K) with the CN518 / PN-2261D from 98' Maxima and the steering wheel controls didn't work even with the connector being in place. I've ended up swapping the CD player part between the two and everything works perfect now. Hope this helps.
FarFetched
Thanks !
99q45t_vl wrote:If you want to use the radio from 96 thru 98 - they should be the same CN423 / PN-2121 model. My CD player in 99'Q went south and I've replaced it (CN588 / PN-2261K) with the CN518 / PN-2261D from 98' Maxima and the steering wheel controls didn't work even with the connector being in place. I've ended up swapping the CD player part between the two and everything works perfect now. Hope this helps.
the one I'm looking at is CN435,PN2121NB and I believe mine is CN423/PN-2121 so they should be pretty much the same, right?Cheers!
Q_SHIP
They were double stacked.
99q45t_vl
Car: Grey 2014 QX60
Do you have the steering wheel controls? That can be the only area of incompatibility.
FarFetched
my Q doesn't have steer wheel controls, so it should be a problem!I'll ask people who sell it!thanks!
