Y33 Alternator - HELP
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
I did something really stupid -- dont laugh please, I changed the battery on my 1997 Q45 (80k), and connected the terminal in the opposite direction. Well, other than seeing the 4th of July under the hood, I blew the 120Amp fuseable link. I changed the fuse and carefully connected the battery in the right direction. The car started.
I measured the alternator output - at start-up it reads 14.33 volts (winthin spec. range). As the car warms up to ideal - the reading drops to 13.85 volts. The reading doesnt seem to stabilize... it keeps dropping to about 13.33 volts after 30 minutes in ideal. Under a full load, AC, all lights, etc., the output in the worst case is about 12.86 volts.
I just started to pay attention to the alternator since I changed the battery - it may have been doing this all along -
whats going on..... Is this normal? The funny thing is that at startup it reads perfect output - 14.33????
CJ
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
i assume the 12.8V is at idle? if you bring the revs up to 1500, does the voltage increase?
since you have a dvm, also look at the voltage when you trun the car OFF. if it goes from 12.8 up toward 13.2-13.5 or evn higher, then your alt is not up to snuff.
at least the alt is WAY easier to change on the fy33 than the G50....
CJQ45
Yes - the 12.8V is at idle with a FULL load - lights, AC, etc...
When the car is off - the volt reading is constant - 12.7 volts - it does not change.
What does the volt reading when the car is off tell you about the alternator... just curious.
CJQ45
Oh .... and the voltage does increase as I up to 2000 RPM. If the reading is 13.44 V in idle at 650 RPM.... the reading goes up to 13.50 volts at about 2000 RPM. However, it comes back down as the idle returns to 650 RPM
FarFetched
Car: Suzuki SV1000S.
To truly test alternator you have to create load on the system .Observe Volts as well as Amp reading. You need a load tester with a carbon pile (or equivalent) to do it. With DVM you can only test V output which isn't for complete test.It looks to me that you fried voltage regulator. Bummer it is Go to a shop and test alternator output. All I know it should not exceed 15V at 1500-2000RPM. Test load goes till you get max lad reading on system - that would be Amp output of your alternator at idle or 1500-2000RPM.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
CJQ45 wrote:Yes - the 12.8V is at idle with a FULL load - lights, AC, etc...
point being if the battery is supplementing the load, then turning the car off will remove that load and the battery voltage will recover.
a 0.06v increase is not enough at 1500 revs in this case, although it is an idicator that your alternator is not *completely* dead. my guess would also be voltage reg at this point.
my guess--only a guess-- is that you could probably nurse it for a week until you get a factory reman shipped to you from a sponsor.
