I'd agree, as just cause it looks thicker/stouter doesn't mean it's made with the same quality materials or to the same standards. Doesn't mean it's not, but the trouble is there's no telling ... unless it breaks when you need it the most .elwesso wrote:those arent bad, but i prefer to go with name brand since the tension rod takes ALL the force upon braking.
And all the longitudinal load on acceleration!elwesso wrote:those arent bad, but i prefer to go with name brand since the tension rod takes ALL the force upon braking.
Finally got the rods installed today. I guess I'm the first Y33 owner here with adjustable tension rods! The ride is little stiffer, but controllable. The caster is +6.3 on the left and +6.4 on the right. The left pull is GONE. Thank you guys for help. Merry Christmas and Happy New Year.elwesso wrote:You can run adjustable ones for the 240/300ZX as theyre the same.
