KingKarl »
https://forums.nicoclub.com/kingkarl-u27127.html
Thu May 28, 2009 8:29 am
Thanks Ted. You had offered help previously when I was trying to get mine out without causing catastrophic damage. I was obviously unable to do so but would really like to avoid this situation in the future.
The whole suspension refurb. project turned into an expensive ordeal with lots of surprises because I was unable to verify a certain part of the maitenance/service history of the car. When I was test driving it prior to purchase 4 years ago, the previous owner remarked that he had just had the front end "done." When I asked "by who" he said "by the Infiniti Dealer." NOT!
Whoever did the job had an unhealthy fixation on the use of the pneumatic impact wrench. So much so that I broke two 1/2 inch drive, 17 mm sockets and a 1/2 inch breaker bar (all "lifetime warranty" tools) removing the strut/stabilizer bar links and tension rods. Also, the strut in the worst shape, as well the Tension Rod bushings were "aftermarket" junk that had failed miserably in the 40k miles that I had driven the Q. But thanks to IOS and job security, I'll soon be back on the road and up to spec.
