Y2K with window rattle
zwing8
Car: 1981 280zx
Hi All. My 2000 Maxima has a window rattle on drivers door. It's OK when it's rolled up, but when its down even a little it rattles when I close the door. Anyone know how to fix that?
Also, while I posting, the drivers door sags a bit. Do I need new hinges?
Thanks for reading this. Let me know possible solutions.
Thank you, Jim
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Welcome.
Pull off the door panel and have a look inside. Make sure everything is properly secured, lubricated, etc. If that doesn't stop the rattling, it should at least help you determine what's causing it.
Unless the door hinges are bad (I doubt they are on such a new car) you should be able to simply adjust how the door hangs.
