Ok thanks! very helpfulmiamiheat3332 wrote:Nope, best option is what i put in the 2nd edit.
sicwitit wrote:I second Innovazn's comment.
the only other way to really open up your exhaust is to make some equal length headers, routed into some high flow cats, collect them in a y-pipe with a 2.5'' outlet, and into a single in/single out muffler. All bends will need to be mandral, and all welds should be tig'ed.
I feel like the last 3 yrs have been wasted because I could of been producing a complete exhaust for quite some time now. I've got some headers already that I'm 90% sure will work as a model to follow. I should be complete with my move in a couple months to include moving somewhere that has enough room for all my tools, and enough room to build some prototypes if your willing to wait. If not, then any competant welder can design something similar.
JT
what do you mean by" collecting them into a y-pipe with a 2.5" outlet" ? I thought you agreed that the y-pipe was a waste of money. Sorry for the noob question but I dont understand.sicwitit wrote:I second Innovazn's comment.
JT
Well thats what I was thinking of doing. Collect the headers using a y-pipesicwitit wrote:the piping from each header has to be collected somehow right? so, you can do it with either a two in-one out muffler, or use a Y pipe which will do the same thing, cost a little less, and it will scavange a little more engine sound over a muffler or resonator. Thats all i'm saying.
the 2.5'' outlet is recommended only because we need a little bit of back pressure to make the cats function correclty since I havn't heard of anyone on these forums running forced induction on the Vq35 we all have. well, not yet, I do have a few turbo's laying around...
If it gives some hp and/or torque and its not too expensive, I will get the y-pipe thenInnovazn wrote:But now youre wasting money on a Y-pipe.... why not ask the shop what the cost difference is between straight 2 in 2 out / 2 in 1 out / 1y pipe, 1in i out ?
Its limited to 105 MPH, but its not about top speed that I care about its just a little more acceleration that I wantInnovazn wrote:If thats what you think.... how fast have you gone with your truck?
Ill tell you right now, it wont help if you gain a touch more hp or an ounce of torque... its still an suv and that added hp/torque you THINK you put on it... is just wasting money.
I have hit 169km/h going down hill and floored.... you cant go any faster without your governer kicking in and stopping you from going any faster. enjoy wasting money yeah?
and as you said "claims on the internet"
ANDDD another note.... you dont have custom headers (and i doubt you will unless you s*** money) AND you wont be mandrel bending your pipes either (again i doubt you will unless you s*** money)
Arguably enough, crush bending and mandrel bending is near 500 dollars difference if not more. and a Y pipe + single in single out muffle will cost your MORE then a dual in single out... and SURPRISE it does the same thing :o
besides, there isnt much that you can do to a pathy, so Im willing to spend a little extra, since this is probably the last mod that I will do to the path and im also looking for a possible air/fuel tune.
It does not matter if its limited to 105 mph because its not practical to drive over 100 mph, so I just want better acceleration.Innovazn wrote:PathPro2002 wrote:
2 in 1 out reso delete.Anamagous wrote:Hey guys,
Can anyone draw up a sketch of what It will look like once the two res. are eliminated and I put on a 2-in 1-out muffler? Also, what is the least expensive option to improving the exhaust. remove resi, 2-in 1-out muffler -----or----- remove resi and place a Y pipe directly after the cats into a larger diameter pipe into a 1-in 1-out muffler. Which one should I go for? seems like there is a lot of opinions about it in this thread? your advice please, thanks
What do those plans include??sicwitit wrote:I love the X-pipe idea too, I've seen a very dope setup on a 600SL done with an X-pipe. only difference is it had 6 more cylinders then our Pathy's have! Well, maybe thats not the only difference, but you know what I mean.
You probably won't see any real benefit from a Y-pipe. Our engines just don't make enough power and unless your willing to invest some serious bones at building the engine, then you'll never see anything come from it.
Now if your a skilled welder, understand thermal and fluid dynamics along with mechanical engineering, and are just bored off your a**, then have at it man. get it done before I attempt to find out what I can. build a simple system that sounds the way you want it to and keep on truckin!
BTW, I'm back in the US now...and have all sorts of plans....stay tuned!
