gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Mar 30, 2008 4:12 pm
Yes replace your thermostat. Also check on the water pump. See if there is coolant leaking from the weep hole.At some point invest in a good quality water temp. gauge. Don't rely on the dash gauge. It will not tell you when things are getting bad, just when things are shot.
