xxr 002 16x8 +0, fit z32 brakes...
poshatch
Car: p.o.s. 1990 240sx hatch
the answer is nooooooooooooooooooooooooooooooooooo
which sucks, the spoke design dosnt allow for it
wheels all new and fresh
back side of the wheel
before fitment
ok so what i did was...i used washer i got from osh to see how big of spacers i would need to run in order to clear them beasts
the answer is it would most likely clear with 2 washer roughly 5 mm so to be safe run 7mm
which you can find on ebay for pretty cheap i belive
this allows for enough thread sticking out for roughly 7-8 revolutions for the lugs which apparently is about what sentra ser spec v's have stock so extended lugs wouldnt be needed
fitment on stock body, would requires a nice pull and slight camber
soo have fun yall, i hope this helps other out, i knew i couldnt find a good answer so hopefully this helps others
r3v_v3ng3
Car: 91 fastback ka-t
thanks for the heads up
biggie
Could have saved you some trouble on finding that out. I'm sure I posted it a year or more ago.
mRodiek
Car: Stock Hatch
biggie wrote:Could have saved you some trouble on finding that out. I'm sure I posted it a year or more ago.
Major fail.
Only way to learn though right?
poshatch
DriftBoy07 wrote:Major fail.
i fail all the time, it happens lol
and i looked around and found nothing, getting info wouldnt have changed my mind or affected my choice in any way
knowing ahead of time would have only got me the spacers and wheels waiting while my yokohama parada spec-2s come in lol
