Xterra water leak
CpDad
I have water leaking into the passenger side floorboard. It's coming from the a/c unit but really don't know what the cause would be. Could the cabin micro filter be clogged, or is there something wrong with a drain line or what? Any help would be greatly appreciated
xckid
Car: 2004 Chevy Blazer ZR2
its probaly your drain line..either cracked or something not really sure where it goes to. but just take alook at it see if you can figure somethign out
welcome to nico by th way
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
As stated above, check the drain tube for blockage.
