xterra vg33er distributor failure
NAPA280
Car: 2002 Nissan Xterra sesc 4wd
2002 xterra supercharged engine distributor seized. Took it to local shop, they replaced the distributor and said it ran rough for about a minute and then cut off. now it will crank but no start. The mechanic said that when the distributor froze it damaged the camshaft and would cost a couple grand to repair. Any insight if this is what really happened or how to check it out would be greatly appreciated. Truck is in perfect shape and don't want to scrap it.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
he may be right if it truly seized up.
NAPA280
would it not have just broken the timing belt or does the distributor gear drive off of the right side camshaft?
