evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Apr 28, 2010 9:07 am
the xterra/frontier vg33ei is a single cam motor and the intake manifolds are completely diferent as are the heads (this means you can't use the vg30ei intake ont he vg30de block)and even if you could the sc doesn't move enough air to be meaningfull, you'd need a larger sc to make any real power
as fro the rear mount it's been done, it cheaper to sell your n/a and buy a tt, yes you can do it with junkyard parts and you can engineer a lag free system (most people just don't understand enough about boost and make vague statements) if you know what youa re doing, there si 1 on here but he's using a very small single turbo and while he hasn't dyno'd it I'd be suprosed if he exceeded 200-250 whp
for 5k and up you can buy a factory TT, no shipping clips, no collecting parts, no waiting, no sleepless nights, and you'll have a propper "C" code car nto some hackjob swap, and then you sell your n/a to offset the cost, the cost difference int he models keeps on shrinking
