XTERRA SE-to-OFF ROAD Bilstein shocks/struts compatability question
ATOMGUILD
Car: 1987 Nissan Maxima GXE
I have a 2006 XTERRA SE and would like to put some Off Road packaging on it - specifically, I like to put on Bilstein shocks and struts which are OEM for the Off Road Xterra's. *BUT* before I do I'd like to verify if they are compatable with my current SE's stock suspension or is there additional hardware involved to do the switch...?
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
As long as you get the Bilstein ones that are stock length equivelant they are perfectly matched to your Xterra.
You will enjoy a very responsive ride when you change it over. It won't feel soft in the corners like a stock chock tends to do. You will also notice a slightly stiffer ride on the trail which is useful when trying to keep your 4x4 under control.
hsckris
Car: 07 V8 4runner
Big-Bird wrote:As long as you get the Bilstein ones that are stock length equivelant they are perfectly matched to your Xterra.
True but I have no way of finding this out short of going and getting the parts and measuring... right? Does anybody know already?
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
I have done two swaps which art direct bolt in's.The factory mounts are identicle.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
ride height and everything will be the same...you just get different, more agressive shock valving with the Bils.
typhus
Ive been trying to find some Bilsteins for my 2004 pathfinder but havent been succesfull. Does anyone know if Bilstein excluded certain years of Pathfinders for whatever reson?Wanted to go with the Bilsteins, but since I cant find them anywhere, I might have to settle for the KYB's.
Any Bilstein gurus out there?
