PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.html
Mon May 23, 2005 4:34 pm
Plz Excuse the typos:
There are probaly cheaper timing boxes out tehre, than the J&S, which is kinda the Mercedes of timing boxes.
MSD makes some for a lot of applications, I wouldnt be surprised if yours is among them.
This is justa s a safety issue, for your engine, luckily you live way out east were the gas is better than in Cali.
Timing change was something I mentioned beca\use if you add psi, you compress the gas/air mix more.Which makes it hotterWhich makes pre-ignitoion more likely ( knock) which of course can destroy engine.,m witha s mild an addtitiona s you desribe , just colder plugs and thicker oil might be enough to run safe if you only gas up premium.
I cant gurantee of course that you will be totally safe, but can only say if it was mine I'd feel safe enough to accept some extra risk and have more fun with the vehivle.
Like I said the other guy I know thats done this on this platform has it at 11 psi and drives it hard.
I am not sure what stock setting is, maybe 6 or 7? ( anyone?) so adding 3 probaly puts you at 9 or 10 psi.
Not chump change but not a huge problem I hope.
I do hope some of our better techies jump in here tho cuz my experince is limited and I can only sy I would acept the rest-risk that exists after precautions, even w/o an intercooler.
So it all depends will you atke the risk..Is it finaced , your only ride, and you are feeding a family and dont have much reserves in $$, then I wouldnt do it as it voids teh powertrain warranty.
Are you single and have extra money to play with, and not worry too much about warranty and just wanna have fun, mixed with some reasonable reliability but are willign to accept a higher maintenance load ( kinda like me) then go ahead
Fred..
