xterra motor swat (just for fun)
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
i was wondering if it would be possible to put a vg30dett in an 01 xterra. just curious not really serious about the swap.
Raxephon
Car: '04 RX8...for the moment...
wa-chiss wrote:i was wondering if it would be possible to put a vg30dett in an 01 xterra. just curious not really serious about the swap.
With enough time, money, and effort anything is possible.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Note that you can't just swap the DE heads onto your VG-E, so you'll need a whole VG30DETT, but that's okay because the DETT internals are better than the VG-E internals anyway.
The biggest issue will be fittment. The VG30DETT is BIG, with it's twin intakes, twin turbo plumbing, twin intercoolers, etc. It makes the VG-E look tiny. Also, the VG-DE heads are quite a bit larger than the VG-E heads. There's probably room, since I don't think the Xterra engine bay is any smaller than the Z's (if nothing else, it offers more vertical space).
I'm also not sure if the VG-E and VG-DE share mounting points, but those could be fabbed in the event that the do not.
You may also find this article interesting: http://www.nissanperformancema...inder/
They used VG30DE rods and bigger-bore VH45 pistons in a VG30E to create a 3.4 liter VG-E.
Other power options for your Xterra using the stock motor:
Factory supercharger (if it hasn't got it already).Z31 VG30ET turbo on your VG33E. Worth experimenting with.
Or combine the turbo or supercharger with the above mentioned 3.4 liter build.
