Xterra locking rear diff?
mudonthexterra
Car: 2004 Xterra SE 4x4
Does anyone know of a manufacturer of locking rear differentials for the '04 Xterra 4by? I have looked around the net and can only find them for America's 'big 3', Jeep & Toyota. I even found 1 for Suzuki of all things . What make of rear axle does the X have? Thanks in advance, all.
Best Regards,Joel
NISTECH
When you say locking rear diff are you reffering to LSD?
If so nissan has a dop in unit that is lsd.
The reason you are seeing aftermarket units for other lines is they are typically dana rear ends. I am not sure of the maker of the nissan diff but it is a much different design. On that diff the whole pinion and diff assembly come out from the front. Rather then just the diff and ring gear droping out the rear like other manufacturers use.
kc4x4
Car: nissan frontier
Check out http://www.4x4parts.com I'm sure they have what you are looking for.
