JW51 »
https://forums.nicoclub.com/jw51-u309922.html
Wed Jun 14, 2023 7:25 am
New guy here with an oddball question.
I am looking at Frontier/XTerra rear ends for adaptation into an early 50s Chevy pickup. The width and lug pattern are perfect, they just have metric studs. I know someone who put a 2001 XTerra rear end into his and loves it. He raves about how easy the parking brake was to adapt to the original Chevy linkage.
I’ve done some initial scouting at my local self serve yard. I’m familiar (thanks to this forum) with the door jam sticker and how easy that makes ratio identification.
My acquaintance used a 4.6 ratio rear with a removable rear cover. What little research I’ve done on the rear end options for XTerras suggests that some might have been like that, and others were no rear cover with removable third member. That ratio makes sense for his trans and tire size and usage.
Here’s what I’d like to accomplish, if possible: the simplicity of the XTerra parking brake linkage and a gear ratio numerically in the 3’s, with drum brakes. Mid 3’s would be perfect. All that I’ve seen at the yard are something like 4.3 or 4.6
1) Was early Xterra offered in such a ratio? Or is there a third member that would swap into an Xterra housing?
2) I have located a 98 Frontier rear with a HF35 sticker. Could that third member be swapped into a third member type Xterra rear?
3) Could a hybrid approach be employed? Perhaps the XTerra brakes from the backing plate on out…bolted onto that 98 Frontier rear?
4) Perhaps the most practical approach is just to use the Frontier 3.5 ratio rear and figure the parking brake out myself.
