Afliction523 »
https://forums.nicoclub.com/afliction523-u49467.html
Mon Feb 26, 2007 2:43 pm
I have a XTD stage 3 also. It does bite hard. I like it, the only thing I would change is a firmer pressure plate. I like a firm clutch, mine feels a little soft, but not a soft as stock. I did my 5speed swap, and first clutch install myself. I have had no problems. I installed new oem master, and slave cylinder with a staneless line in my swap. I put a koyo throwout bearing in, and also the pilot bushing. The price can not be beat, and even if i had to change it I would not care. The transmission can be out within a hour, change the clutch, and put it back in within two-three. This is just my opinion. If it fails, its myfault for buying a "sHi&*y" clutch. I would reccomend it, but if you like a hard pedal be sure to get a different pressure plate.
Just my .02
