XTD Clutch Alignment Tool
josephrm
Car: 1995 Nissan 240SX SE
Okay, So I go to install my clutch and the alignment tool is loose as hell in the end of the crank. The alignment tool is stepped, and the end of it is too small. The next step is the inside diameter of the pilot bushing. I must be doing something wrong.
BTW, RB20DET, XTD Stage 2 clutch, Cusco Chromoly Flywheel
Any input would be greatly appreciated!
Joe
you cant physically push it in farther?
Shocker
Car: 89 240sxHB rb26/30
might possibly be the wrong alignment tool... you did place a pilot bushing into the crank right?
Carl H
wrong alignment tool most likely, had this same problem when i put a 'new' xtd clutch on my 20...gotta go get a nissan one.
josephrm
no, i definetly have the pilot in there.....that's what i'm thinking, carl. it's not really a big deal, i guess. it was just frustrating this afternoon when i wanted to put it on. btw, my harness is coming out this weekend, and then I am sending it to you! I'm the guy that has emailed you several times starting in february. i am finally getting off my lazy *** and getting this swap done.
josephrm
yay, $2 fix
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Yep get a nissan one. I have put 3 spec clutches in nissans. One kit had the wrong disk. Both alighment tools were loose. I just wiggled them around till I found what looked like center then tightend the pressure plate down. Then I slid the tool back in there to see if it went back into the pilot with ez. I never had any problem getting the trans to bolt back up. Make shure you slide the new disk on the imput shaft to make shure it has the correct splines. This cost me a week on one engine I was trying to put in. I was also ready to shoot somebody. O well now I learned and I have os gikens for both my rb swaps. Some people just use tapered end deep sockets to align the disk.
