its clearance is worse than the stock elbow.300Plus wrote:So do you think this elbow with spacers would clear? I guess I'll just have to test fit everything and go from there. but I guess no one has bought this elbow for this swap? that might tell me something
Any chance you might have any of those spacers left? I will buy them from you. None of my local shops want to do any work on my car.jmdser wrote:I'm using the stock 02 housing with spacers. http://nissaninfiniticlub.net/...age=1
It should definitely clear if you use some spacers.300Plus wrote:If the problem with clearance is on the inside bend of the elbow, then this elbow should clear the same if I use the spacers.... wouldn't you think? I've had a few guys tell me they have it but not installed yet.
This can be easily remedied by using flanges as spacers. Get the flanges cut with a separate hole for the wastegate. Someone on the forum had a few extra flanges a while back, but I cannot remember who it was.Vkoslak wrote:But if you use spacers with the XS, you lose the fully divorced wastegate.
Because the divider isnt long enough.
Might be able to get someone to make a longer one though.
