XS exhaust manifold problems?
bobbyhill
I bought a XS power exhaust manifold for my SR20. I put it on there and after a month 2 of the 4 studs on the turbo inlet snapped off. This is the 2nd time that its done this in three months. Could the studs be snapping off because of my Cusco motor mounts or heat from the manifold, what do ya'll think?
Thanks
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
your manifold is crap. Megan racing is the best way to go if your tight on money
CMG
Car: 1989 240sx Hatch w/ Redtop
Maybe you're torquing the studs too much and after a while of heat and vibration they break. Is the manifold and dp braced properly? Are your exhaust hangers worn out?
bobbyhill
how much should you torqe them down to?where should the hangers be on the dp and manifold?
CMG
Don't know the
bobbyhill wrote:how much should you torqe them down to?where should the hangers be on the dp and manifold?
exact specs, but I use an open ended wrench and tighten it real good but don't torwue it. Your dp should either have a bracket that you can bolt to the other side of the bracket on your transmission mount. If it doesn't have that then try to modify a stock one to work or something.
