Xmember swapping?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
jay-spec013
Mmmkkkk I' am 99.9 sure the 300ZX(Z32) Xcrossmember fits on an S13 no problems. After doing a butt load of research I' am pretty certain the VH bolt in the J30 just buy rotating the mounts 90 degrees.
PLEASE PLEASE has anyone swap a J30 /Z32 xmember in a S13? Iam under the impression since the Z32 and the J30 use VG30DEs the VH should bolt up to car.
The reason I ask is because I know folks who just swap over the skyline xmember when doing the RB swap. I' am just hoping we have that same luxury.
Nycist
Car: eg6, s30 vh next summer..
this would be very helpful. i doubt the j30 crossmember just bolts right in though.....ill do some checking on that..
Nycist
posted in a vg->s13 swap thread...
importdragon240 wrote:
jay-spec013 wrote:I don't see what so hard about this swap, I mean get a Z32 Xmember which bolt right up to the S13/S14. The think the N/A Z32 uses the the same transmission as the S13 so just do a simple bellhousing swap. We already know the motor fits, apparently better than the Z32. I saw something about notching the frame, but for what the exhaust? I have done a search I found so useful info, but I' am just wondering if the Z32 Xmember is swappable and the N/A trans is identical(internally) what makes this so hard. Please people what I' am I missing here. I know obviously its not that easy or it would be more common. So what I' am I missing guys?
importdragon240 wrote:Exactly! I'm doing the VG30DETT swap in mine. Just got the motor today. We already figured I'd need the xmember, so I got one.
interesting
efeezie
No the J30 Xmember wont swap into a S chassis. It bolts up totally different.
Im not even sure about the Z32 xmember into a S chassis. I have a VG powered S14 but I dont have a Z32 Xmember so I cant confirm or deny.
Carl H
will not fit.the z32 is wider.much much wider.
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
I wish the J would bolt up to the Z, or the Q up to the Z. would have saved from the P.I.T.A. work I did on my x, mostly due to using the factory headers. I had to cut up the sides and majorly reinforce to get it super low. VH45 fits grerat on J x. Just my experince.
jay-spec013
Carl H wrote:will not fit.the z32 is wider.much much wider.
R U sure? because the skyline(BNR34) is wider than the S13 and that xmember bolts rights on.
Carl H
has to do with framerail spacing, the r and s chassis share the same frame rail width which is why you can swap xmembers.
BACARDI_DWB
what is the distance between the s frame rails?
SuperHatch
Car: 96 TLC
BACARDI_DWB wrote:what is the distance between the s frame rails?
If I had to guess, between 27 and 27.5 inches.
The Z spacing is 29 by the way, and the stock Q mani's fit with about .5-.75" of clearance on each side. The Q mani's don't have a hope or a prayer to fit between the S chassis framerails.
Carl H
i got the passenger manifold to fit barely between the framerails on my car but there is no way in hell that the drives would fit.
Return to “VH45DE / VK45DE / VK56DE Forum”
