Xmas Lights on my Dash - Slip, TCS Off, ABS, SES - All On - Help?
albertaboy
2002 I35 w/100k
Well in the spirit of Christmas my car has decided it too wants to partake in the festivities--it's decided to turn four of it's dash lights on all at the same time...
I have not yet pulled the codes as I don't have a scanner, but that is coming today...
I do take amazing care of my car. Service is completely up-to-date and I have all history--don't think it's from neglect--rather my hunch is it has something to do with the weather.
Any quick thoughts as to what the problem could be? As they all came on at the same time (last night) I suspect they're related. It's been pretty cold here...
Thanks in advance.
Sorry for the lousy camera phone picture...
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
fuse
D_roc
Car: 2001 Maxima 20th aniv edition
best thing to do is get the code, go to autozone they'll do it free for you
albertaboy
It it showing two codes...neither or which have anything to do with the lights on the dash (I don't think...).
P0455 - Evaporative Emission Control System Leak Detected (no purge flow or large leak). I am hoping this is just the gas cap. Will replace and see what happens.
P1448 - Evaporative Canister Vent Control Valve (Open). Again thinking (hoping) it could be the gas cap, but my gut tells me it's the purge vent valve sticking open.
Don't think either of these codes would cause the light show on the dash though, right?
Thanks for your help boys...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Evap codes will trip the CEL.
What are the other 3 lights? (I don't know the 5th gen dash all that well)
A lot of the time, Evap codes are caused by a bad fuel cap seal.You can check to see if your cap is sealing a couple of ways. One is to simply unscrew the cap after you've driven for a while. The tank SHOULD be pressurized at that point, so you should hear a hiss as the pressure is relieved when you remove the cap. If you do, you know the cap is sealing.The other is to simply try using a cap you know has a good seal to see if that solves the problem.
I don't recall if the 5th gen needs the computer reset to "notice" that the Evap problem is gone or not.
Still, there's no reason that code should be tripping FOUR lights.
albertaboy
The three lights (TCS OFF, ABS, SLIP) are all from the same problem--Left Rear ABS Wheel Speed Sensor. Is this tough to fix?
Any help here is appreciated.
The SES light was from an Evap Cannister (which I sort of figured). I paid them to do that one (which pained me to do...)
