Well, then you are set, you currently have an XM tuner that is located near the spare tire. On '09 Muranos WITH Navigation, the XM tuner is integrated into the audio control unit under the dash, thus not replaceable or interchangeable. If you have any questions, let me know, I actually have a few pages of the service manual printed off, but the tuner is located just in front of the spare tire (between the spare and the back seat). All you need to purchase is a new Siruis tuner, and pull out the XM tuner. The antenna lead will plug into the Sirius tuner (you have to cut off a small piece of plastic for the antenna lead to plug into the new Sirius tuner).dnicect wrote:i have a LE with no navigation
Keep me posted and let me know if you have any questions!dnicect wrote:i order the tuner on firday when it comes in i will be installing the tuner some time next week.
I don't believe that unit will work. dnicect is correct. You need a Nissan Sirius tuner, you can order if from any Nissan or Infiniti dealer. http://www.mynissanparts.com is a good place to purchase from. I also found it here: http://www.grubbsperformance.c...=2905bruceabosco wrote:I just purchases a 2009 Murano LE with no navigiation and am also looking to swap xm for sirius.
Is this the receiver to get? Will I need to purchase anything else?
SiriusConnect Vehicle Tuner Model: SIRIUSConnect Vehicle (SCC1) Price: $49.99 http://www.sirius.com/servlet/...98317
I doubt the dealer would want to do it, and if they did, they would probably really sock you for the labor. It is actually a really easy swap out, totally easier than changing a spare tire, that is for sure. I think just about anyone can handle it, you locate the receiver (near spare tire) and switch out the tuner. You will have to unplug a few things from the existing tuner and then plug them into the new Sirius tuner.bruceabosco wrote:Thanks guys for the info. I will probably wait to order mine until I hear how it goes with Dnicect. Then I may attempt to do it myself if it's really easy. I dont know alot about cars so I am very reluctant to do this myself. I was thinking about asking the dealer's service dept if they could do it for me.
Any info on if the dealer would do the swap?
Should work out fine. I pulled the receiver out of my 2005 before I traded it in and installed it in my 2009 in about 20min. Only modification was to the antenna connector. Had to cut off the Sirius teeth so that the XM antenna plugged in.dnicect wrote:i have 1 more ?. can i use a tuner from an 2006 murano w/o nav and it has a bose system.
Leftarm is CORRECT! All you have to do is cut off the teeth on the antenna plug, and it will plug right in.Leftarm wrote:
Greetings to NICOclub! Glad to have you here in the Murano Forum!Megatron26 wrote:Timmbo,
Can this be done with the 09 SL no navigation ???
Gotta have my NFL....
Thanks
MT26
How about on a 08 Pathfinder with Nav?am I screwed because of the NavtrafficI hate XM, reception is way worse that siriuswould love to convert itThanksTimmbo wrote:
Hope this helps, please let me know if you have any questions!
