MMPACK1 wrote:Thanks for the quick reply Telco,
I purchased a three subscription from XM in the end of March, I've been using the XM radio everyday since then until about a week ago when this problem occurred. I had no problems with the May 4th upgrade either.
I have the radio ID from when I started my subscription. Now I cannot change the channels at all, it only says "loading" and won't do anything
Hmmm!
Before concluding it is a hardware issue call Sirius XM customer service and ask for tech support or tier 2 tech support and describe the problem
If you can locate where the antenna connects to the radio unplug it
Your display should then change from loading to antenna not connected
