blaruffa wrote:Thanks, I was thinking of pulling out the Sat receiver out of the Rogue and transferring it to a Pathfinder, but I guess that won't work based on the part #'s.
Actually you should be able to do this. Firstly, your Pathfinder must have the SAT radio ready audio system with the in-dash 6CD changer. You just need a few things:
999U9-XS000: Nissan Pathfinder Sat Tuner Bracket, fits the #999U9-AS005 XM reciever
You may also need the harness and antenna part no's I quoted above. If your Pathfinder came pre-wired, the only issue you may have the antenna. In this is the case, you just need to purchase a proper glass mount XM antenna.
Hint: do a search for 2005 Pathfinder sat radio and you should be able to find a pdf version of the sat radio install manual. This will tell you everything you need. Ignore the part no's for the XM reciever, apparently the newer one from the Rogue should work just as well from my research.
