Contact Joe Tsensky at http://www.everythinginfiniti.com for information. This site is part of Scottsdale Infiniti in Arizona and gives us excellent prices on OEM stuff.evanjmprice wrote:so the car is fully wired for an XM module in the trunk? All I have to do it buy a module and an antenna and it will work through my existing display in my dash? That's bad a**.
EP
Who do I talk to about doing that?
It doesn't mount in the trunk lid. It goes under the rear parcel shelf behind the right rear seat. Remove the trunk top finisher and you will see the connector.NightWatch wrote:Your car is pre-wired to connect to the factory XM Receiver module which mounts in the trunk lid.
Hey mcdoken, I know this is off topic but were you ever able to find out information on installing the back-up camera into an M that didn't come with one from the factory?mcdoken wrote:
Here's a link that shows how to install the tuner and antenna. Although it is not the factory shark fin antenna.
http://www.infiniti-parts.com/...T.pdf
My car already had the back-up camera so I didn't do any research on it. But I saw a post on another site from somebody that installed Navigation and also wanted the camera. He found that you have to change the trunk lid to the one that has the recepticle for the camera. And then also install the wiring to it.hoaapple wrote:
