BCole8888 »
https://forums.nicoclub.com/bcole8888-u270590.html
Tue Dec 27, 2016 9:10 am
It's as you described, I don't have clear path to the sky issues, it works normally then. But every underpass causes it to cut out, and I've never had that happen in other cars. There is one underpass on the interstate where it cuts out 3 times. Once when I'm about 300 yds away, again as I'm drive under it, and a third time as I drive away from it. My wife's QX60 maintains a signal without a drop in the same spot. I see there are aftermarket antenna replacements, just didn't know if anyone has ever gotten one and it fixed the issue.
