XM Commander MT Installed
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Eemrek
Car: 2007 Nissan Versa SL HB CVT
Finally had the guts to partially disassemble the center console.
The XM Mini-Tuner lives in the upper "cubby" hole (hidden) so I can remove the Mini-Tuner when I'm at home to use. Tapped into the ACC which powers the OE HU to power the XM. Routed the "Control" unit below the center console just above the cup holders. Was going to use four screws for the "mounting bracket" but just ended up using some 3M double-sided industrial strength tape.
Decided to go the FM modulator route and picked up the 40-NI32 Metra Antenna Adapter Kit for $15 USD shipped. That way I can keep the front AUX plug available for when I want to use my phone to playback Pandora or something.
Cheers,
Eemrek
williamk10
Car: '07 Nissan Versa SL
Looks good, how does it sound like from the FM modulator? From my experience with my ipod, it wasn't very good. Sounded like mediocore FM radio at best.
Eemrek
williamk10 wrote:Looks good, how does it sound like from the FM modulator? From my experience with my ipod, it wasn't very good. Sounded like mediocore FM radio at best.
It's pretty decent. The one that came with the XM Commander MT is the Audiovox FM Direct Adapter (XMFM1). Even on the "higher bitrate" channels like XM 77 & 78 (the classical stations), it's pretty close to MP3-quality. A lot better than the other FM modulators which don't directly tie in between the HU & vehicle antennas.
Although I did notice... after I had my car engine swapped... the OE vehicle AM/FM antenna isn't performing as well as it use to. (Even before installing the XM radio). So I was playing with the antenna harness without the FM modulator hooked up and killed the "12V" power-supply (the blue wire) from the HU which is suppose to drive the antenna's amplifier and it didn't change the reception quality of FM stations at all. Most of the stations in the Seattle area are pretty high output so even with the antenna non-amplified, I still pick up stations with a minor bit of static but they use to come in crystal clear without static before.
I think the amplifier section of the antenna is dead/fried (I measured a decent 12V out of the 'blue wire') so now I'm trying to locate the "base" of the antenna which houses the amplifier to replace to see if it fixes my FM reception.
Cheers,
Eemrek
Return to “Versa Technical Discussions”
