kenlin28 wrote:I had this same problem with my kit. What I did was cut that wire that has the prongs on it and tapped it into the factory harness. hope this helps.
Yeah that's what I was thinking of doing..as a last resort. I was just checkig to see if anyone else had this issue because it seems like some kits work perfectly but then there others that are messed up.
So did you end up hooking up the wires black to black and blue to red? I don't want to blow a fuse or whatever by mixing them up. I'm going to try again tomorrow with the OEM harness and the balasts harness. And if that doesn't work then I guess i'm cutting wires
