XENTEC 6000k headlights....Installation help!
chiefs5652
Car: 08 Nissan Altima Coupe, 2.5 S Dark Slate
Hey everyone. I just got a set of xentec h11 kit for my 08 coupe. Is the coupe a plug and play system or will i need to wire it to the battery?? thanks for your help!
phobs
Did it come with instructions? If it didn't with a relay harness then you don't need to hook it up to the battery.
bina12834
Car: 06 G35 coupe
unless the seller included a relay harness, Xentec's usually dont come with one. it will be plug and play chiefs
chiefs5652
thanks everyone..One more quick question...Just to reaasure, i should disconnect the negative power terminal also while doing the installation. The stick on things they gave for the ballast are crap, any other suggestions? I got the regular sized ballast, if i would of known i would of bought the slim ones.
bina12834
Car: 06 G35 coupe
yea i would disconnect the neg battery terminal
the double sided tape they provide is very strong, but i would use zip ties as well....just incase
if you have the "auto" headlight feature, the larger ballasts have been actually said to have less firing up mishaps
chiefs5652
thanks bina..I am going to install the lights tomorrow and i will try to post pictures to show how it looks. Hopefully it will be just plug and play because i dont feel like spending a whole day doing it.lol. After the lights are done, fogs will go in and i will tint the taillights with LBC overlays..RIMS AFTER WINTER BABYY!!
bina12834
Car: 06 G35 coupe
i guarantee they are plug and play.
chiefs5652
I just popped the hood really quick to look at the lights..Im going to have to take the light out of the car..damn...any suggestions anyone of a easier way or its the only way?
mikegtr06
Car: 1995 180sx
just pull off the bumper ..... my first time removing the bumper it took me 40 min to remove the bumper install the lights, test them and re install the bumper.
BlackNWhite
Car: 08 Altima Coupe
chiefs5652 wrote:I just popped the hood really quick to look at the lights..Im going to have to take the light out of the car..damn...any suggestions anyone of a easier way or its the only way?
You do not, I REPEAT... you do NOT have to take the lights or the bumper off to install the HIDs. It helps if you can put your car on a slanted surface... but if no it can still be done through the wheel well.
Coupeguy23
Car: 2006 G35 coupe sport
chiefs5652 wrote:thanks bina..I am going to install the lights tomorrow and i will try to post pictures to show how it looks. Hopefully it will be just plug and play because i dont feel like spending a whole day doing it.lol. After the lights are done, fogs will go in and i will tint the taillights with LBC overlays..RIMS AFTER WINTER BABYY!!
I got ask where did u get your fog lights from i need some bad im tired of looking at the black wholes and by i have tryed the stuff on ebya it didnt work for my coupe
chiefs5652
thanks SOCAL..im going to try to do it today in this 30 degree weather in NY...haha...If you guys find any easier ways let me know...Thanks for all your help!
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
There are two ways of installing hids for your low beam. Either take the bumper which takes more time but it gives you more room to mount the ballasts and run the wires nice and neat. The other way is installing through the wheel well which probably takes less time but you wouldn't have much room to do a clean installation. In my case, I took the bumper off to mount the ballasts for the fogs and low beam. I also have relay harnesses for fogs and for low beam. Haven't had a single problem for about 7 months now (I have fat Xentec and X-light ballasts).
The picture shows where I mount the ballasts if you need any help. Have fun in the frigid weather
bina12834
Car: 06 G35 coupe
kuhan wrote:
thats where i mounted mine too....perfect location. i have to disagree about the time it takes to get the bumper off. by myself i can take off and put back on the bumper in around 10 mins. once you do it 1 or 2 times, it becomes so easy.
chiefs5652
thanks guys for all your help..I installed them today!! they look sick..ASAP i will post pictures of my coupe on here...Im putting in fog lights soon, tailight tints from LBC after the winter and probably a nice set of shoes to go with it. Later Coupes!
