daretodif »
https://forums.nicoclub.com/daretodif-u172826.html
Sun Feb 06, 2011 1:35 pm
Trying to install XenonDepot's 4300k Bi-Xenon 9007 headlights in my (wife's) Nissan Pathfinder, and I'm having trouble.
I have one bi-xenon headlight installed, driver side. The high beam works fine, no problems. The low beam does not work, and I keep popping fuses. I'm stepped up from the factory 15A fuse to a 20A and a 25A, same thing. I don't really want to go higher than that, and don't think I should have to. I've checked all the wiring/connections. It looks good. The high beam fuse is 10A, if that tells you anything. I think my ground is pretty good, if it was bad the high beam wouldn't work I believe. I also plugged in the other ballast temporarily (to see if its the first ballast) - same thing though.
I really need to get my wife's car operational today (and that might mean reinstalling OEM lights).
Any advice/feedback would be helpful.
