arnage »
https://forums.nicoclub.com/arnage-u37701.html
Sat Feb 25, 2006 8:37 am
Brian and Joe,
Thank you for the welcome and the quick responses. I can't say that I feel very encouraged to embark on the project after finding out more about the difficulties. I spent a few hours earlier this morning doing more substantial research. It seems that there are more complications than I was originally aware of.
Brian: I am aware that many vehicles (typically, the older ones w/ OEM HID) used a halogen bulb for high-beam, as the reaction time is much quicker. To your point, many of the late-model vehicles w/ OEM HID are using a bixenon setup, using mirrors or movable lenses that redirect some of the lighting at an angle slightly higher up from the ground. I think such a setup may be cost-prohibitive.. and besides that, I don't think I am "handy" enough to really try my hand at cutting apart the preexisting headlamp units for the purpose of installing true projectors. I'd probably wind up messing up the stock lamps as well as any retrofit projectors.
That being said, I would still consider that H4 dualbeam setup (as it doesn't require any cutting/modification of preexisting components, while retaining the highbeam functionality) if anyone has tried applying it and could offer input.
Wes: That is one of my concerns -- I know what it's like being bombarded by overpowering HIDs in the opposing lane, and it's not fun. If I were to go ahead with this, I'd try my utmost to properly aim and focus the beams, so as to minimize glare and scatter.
My parents have an Acura 3.2TL (MY 2000, so it was before the clear lamps on the Type-S were introduced). It has the "foggy" looking translucent covering, which leads me to believe that it could have been based on a halogen unit of some sort. I haven't taken it apart (nor do I plan to), so I am as of yet unsure as to whether it has HID-specific projector lenses.
The other car they have is a 2000 LS400, also with OEM HIDs. This car has the clear coverings, which allows you to see the setup of the projectors.
I've noticed that the LS400 has self-leveling beams, whereas the Acura 3.2TL does not (and both of these came w/ the HIDs as OEM). When the LS is sitting at a gradient in the driveway and you start it up, you can see the cutoff actually move to level in an almost "motorized" fashion. The Acura stays as is.
Is it a fair assumption that installing an HID conversion (i.e. - swap out of halogen bulbs w/ HID bulbs and ballast, retaining original lenses) straight into a G50 Q45 would be akin to what Acura had on the 3.2TL? I don't know if a "clear" headlight covering is required for HID projectors, but it seems that it's the trend.
Lastly, having read so much about people settling for silver stars, this has become a consideration. Could you offer any info on whether the lumen output is truly higher than stock halogen on the G50? Similarly, could you show me some sample pictures of them on a G50 Q45?
Thank you so much!
