Xbox issue, I need help
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
My xbox is flashing a red light at the bottom right and it says "E74 please contact Microsoft". They want me to send it back to them to fix. This is my 4th xbox nd I cant afford to fix it. Any suggestions?
bersh240
get a ps3
AppleBonker
Xdisaster240sX wrote:My xbox is flashing a red light at the bottom right and it says "E74 please contact Microsoft". They want me to send it back to them to fix. This is my 4th xbox nd I cant afford to fix it. Any suggestions?
E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
E18 (error 0102): Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
bersh240 wrote:get a ps3
Very original.
RCA
He can't afford to fix his Xbox so you suggest a PS3?
Any who, OP what ever you do, DO NOT DO ANY RESEARCH ON YOUR OWN.You want to leave this to every one else. 5 mins and I found this:http://www.youtube.com/watch?v=Bo2dl2vlwis
Watch all three. Enjoy.
troskinatior
Car: A Two Tone Piggy Coupe
Did you have it for longer then 3 years?Edit: Never mind some one already told you. I wouldn't try fixing your xbox on your own, trust me. I had the same issue(e74) when I called up microsoft they said my warrintey was up (it wasn't) so I tried fixing it and I couldn't get it to work, and I bacically did every thing on the internet.
Modified by troskinatior at 1:07 PM 3/24/2010
ADDirishboy
Car: 2008 Nissan Titan Pro4x
Hit it with a hammer.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
And THIS is why, despite the fact that I own like 40+ pieces of videogame hardware, I've yet to buy an X360.
And I won't buy one, at least not until it's a $100 bargain-bin item years from now.
They need to completely redesign the hardware, a la the PSTwo. Then maybe I'd think about it...MAYBE.
AppleBonker
FWIW, I've got a launch 360 pro/premium that is still completely functional. I've also got a few month old elite. Never once gotten a RRoD on either.
Legion76
Car: 95 Zenki, 99 Ram 1500
My roommate bought my 2nd run Pro 360 and I've had a 1st run elite for the last couple of years and neither one of the them has had the RROD or any other problem.
AZ89two4Tsx
bersh240 wrote:get a stepstool.
fixed that for you
Xdisaster240sX
AZ89two4Tsx wrote:
fixed that for you
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
HashiriyaS14 wrote:They need to completely redesign the hardware, a la the PSTwo. Then maybe I'd think about it...MAYBE.
That appears to be in the works. Spy shots of what appear to be a 360 slim motherboard have popped up. The design repackages the gpu and cpu and should solve the heat problems (this isn't some minor heatsink alteration, but a complete redesign with the CPU and GPU sharing a heat sink).
http://www.joystiq.com/2010/03...pport/
http://www.joystiq.com/2010/03...eaked/
Alfador
Car: 1990 Nissan 240SX Hatch
The firmware update coming up further suggests a redesign. Normal run of the mill attached storage (like flash drives) will be able to be used for full read-write storage for up to 2x 16gb partitions. Seems like a major enough thing that it would accompany a redesigned console.
RCA
MinisterofDOOM wrote:That appears to be in the works...
Saw this when researching the USB HDD rumors...
This is my favorite:
