wut front mount
blk90s13
who using a front mount ?
and if so anyone got a side in/outlet type with both inlet and outlet on the same side ?
i dont wanna go with the piping infront my timing belt i rather run the pipes in the fender as if i am going to the side mount then hook to a front mount instead
or even like a starion type front mount where both pipes go to the one side
Andrew85cm
Car: 89 240sx with RB20det
Personally I dont like the ones that go in the same side as it comes out. They aren't the most efficient intercoolers. I would suggest pulling at 120 or what ever degree that is at the intake manifold and going down to the one side of the intercooler. and then ducting it out on the other side. If you check the Ausie forums I have seen a few people do that. I think you would be better off. ~ANDREW~
